Throttle Position Sensor replacement
Old Nov 7, 2018 | 08:18 AM
curt698's Avatar
Default Throttle Position Sensor replacement
So I purchased my S60 knowing there was a TPS code and knew the cost of the part. I did not think the locate the TPS when making my decision, DOH! I have done a fair amount of research and it seems like the best option is removing the change tube and fan assembly to get to the TPS. Is there any easy method that I am missing?
Standard disclaimer, I did search this sight prior to posting so if I missed a thread or 12 please forgive me.
Thanks,
David
btw car is in my sig and currently has 207,xxx miles on it
Old Nov 13, 2018 | 02:03 PM
pierremcalpine's Avatar
Thanks,
David
I really don't think you need to remove the fan. I've got the '04 turbo version and I was able to easily reach in from the airbox side underneath the intake manifold just by removing a few vacuum hoses and the pipe going to the ETB. You do have to remove the 4 bolts blind but that's not a big deal just go by feel. Just remember the orientation of the TB before you take it out. I put mine in the wrong way around and my engine didn't appreciate it.
Old Nov 14, 2018 | 09:35 AM
curt698's Avatar
Thanks, when the time comes I'll try your method.
mphilleo
Feb 14, 2016 08:50 PM
mjc2
Mar 21, 2012 12:14 PM
dahubb
Jan 20, 2010 07:44 PM
knight rider
Oct 10, 2008 07:41 AM
quarterdimenickel
Jul 8, 2008 10:11 PM
