timing belt jumped
Old Aug 16, 2018 | 06:48 AM
trema13's Avatar
Default timing belt jumped
Hello guys new here, so I have a 2011 volvo s60 and what happened was my air condition belt broke, shredded my other belt to the point it was spinning and cut a hole in the timing cover. After that the belt got stuck in my timing belt and caused the timing to jump. The car died while driving, we tried putting the timing marks back just in case and of course no start. At this point I am assuming the the valves touched the pistons, I dont know if it would be easier to take off the head to replace the valves or to replace the engine. If just the valves anyone know of a good place that can replace them in the boston area? thanks in advance.
Old Aug 16, 2018 | 07:49 AM
tony1963's Avatar
That's a very unfortunate and rare event. However, you are where you are now.
My suggestion is to take the vehicle out of service and remove the head. Take it to a machine shop to be disassembled and checked. You will likely need to replace several valves. They cost around $20 each.
Reassemble and go on your way.
Old Aug 16, 2018 | 08:18 AM
trema13's Avatar
Do you think that there would be any other damage other than valves?
Old Aug 16, 2018 | 08:33 AM
tony1963's Avatar
Usually not. But no guarantees LOL.
Old Aug 16, 2018 | 11:08 AM
ES6T's Avatar
I've seen several of these cases. I haven't had one that had damage beyond the valves. We replace the head because it comes with new valves and winds up being less than new valves and machine shop work.
Old Aug 16, 2018 | 01:59 PM
trema13's Avatar
thanks guys, I am leaning towards a used engine with the same mileage.
Old Aug 16, 2018 | 04:43 PM
I'd compare the engine swap costs with getting a used replacement head installed as well as getting the valves replaced in the old head. Expect to need all new exhaust valves.
Old Sep 1, 2018 | 01:56 PM
Cheeseman's Avatar
Do a compression check on each cylinder. This will tell you if a valve is bent or hole in the piston. Find a friend with a bore scope and look inside each cylinder thru the spark plug holes. Double check you have the timing marks lined back up or it will not start. Make sure the cams are re-positioned correctly. Volvo has one big imagination on these. They suck finding the correct position. Lobe up or down on exhaust and intake cams viewed from position sensor end. Not sure but some models had two cam position sensors and double advance timing hubs. You can pull the head with the engine in place. Only thing if a piston is damaged. Good luck.
99volvo$80
Jul 23, 2016 09:03 PM
wink59
Feb 3, 2011 02:06 AM
Mro111
Sep 7, 2010 02:26 PM
elizabethera
Jun 24, 2009 05:21 AM
twc2002
Jul 14, 2008 12:08 PM
