Tires, Brakes, alignment repairs/replacement
Old Nov 2, 2008 | 05:54 PM
Iggyomega's Avatar
Default Tires, Brakes, alignment repairs/replacement
Hi,
I am needing to take my Volvo in for some basic repairs. I need to get new front brakes and four new tires before the winter. Do you know how much these generally cost for a 2004 S60? I am in Chicago, if that helps. I also think the alignment is off, but I am hoping that my extended warranty will cover that. I bought my car certified pre-owned. Do you know if the warranty covers things like alignment?
Thanks again
Old Nov 10, 2008 | 11:42 AM
psu97's Avatar
Default RE: Tires, Brakes, alignment repairs/replacement
I just put Toyo Prxies IV on after looking around a bit. I got them for about $170 a piece(they are 17" tires), and had the alignment done at the tire shop.($49) I really like the tires. I do not believe that alignment is covered under any warranty, as I believe it is considered normal wear and tear. Also had the front brakes done for about $100...but they were able to resurface the rotors. If you need new ones, that coud drive the price up quite a bit.I am in the northeast, so I can not help geographically there, but under no circumstances go to the dealer for tires.
mexicanfooddude
Apr 15, 2015 06:46 AM
mrvolvos60
Sep 11, 2014 07:39 PM
hrdwdpro
Oct 7, 2013 10:28 PM
Thanman
Oct 26, 2010 10:20 PM
ajwgator
Nov 12, 2009 11:03 PM
