too much oil? will this give the no pressure warning
Old Aug 1, 2008 | 12:26 PM
wayne73's Avatar
Default too much oil? will this give the no pressure warning
just noticed that i had a bit too much oil in the car, will this give me the no oil pressure warning or is it my oil pan oil seals, just asking as the message doesnt come on as often as it did before.
Old Aug 1, 2008 | 06:04 PM
Default RE: too much oil? will this give the no pressure warning
I will bet the o-rings are bad.
Old Aug 7, 2008 | 08:55 PM
notny41's Avatar
Let's just sayit was the o-rings, is that then a misleading message the car is giving or is that a valid message and a serious issue with the car?
Old Aug 8, 2008 | 07:01 PM
The light coming on is usually due to low oil pressure. If the o-ring is bad it causes low oil pressure.
Old Aug 10, 2008 | 11:26 AM
wayne73's Avatar
will driving with this message on damage the engine, all response is there and no turbo issues at all, car feels ok, so is it ok to drive till i can get it looked at, sounds expensive and i need it for a 2 hundred mile journey next week for holidays,
Old Aug 10, 2008 | 08:38 PM
If the oil pressure is actually ok then ok to drive. But if the oil pressure is actually low no good to drive.
volvoQ's
Dec 27, 2010 06:06 PM
AvA
Oct 23, 2010 06:55 AM
battmeister
Apr 3, 2010 08:53 PM
aryanvahedi
Nov 18, 2009 08:59 PM
01VOLVOS60T5
Dec 25, 2008 10:45 PM
