Trans fluid in the coolant UPDATE
Old Oct 27, 2015 | 04:47 PM
mal81394's Avatar
Default Trans fluid in the coolant UPDATE
So this is the story. I keep loosing coolant with no leak and I just kept filling it up. When I went to fill it up on Sunday I noticed brown what I think was transmission fluid in the resovoir container. It had that smell of transmission fluid. So I ordered a new radiator and coolant and transmission fluid thinking there would be a ton of coolant in the transmission and that is where my coolant has been going. Today I drained the transmission from the plug and I got a little over a gallon of fluid out and no evidence of antifreeze or water mixed with the oil. I am confused. First I am only supposed to get 3.5 qts out of that plug right? I did have the car on a hill is that why so much came out or is there antifreeze mixed with the trans fluid and I can't see it? I didn't think trans fluid and water would mix. So, where did all my coolant leak to and why did I get so much trans fluid out? Any help would be great guys I know that was a long post I am just beside myself.
Old Oct 27, 2015 | 05:45 PM
ES6T's Avatar
You usually can't see coolant in the trans fluid. You need a test kit to check for glycol in the trans fluid.
Old Oct 27, 2015 | 06:13 PM
mal81394's Avatar
Default reply trans fluid in coolant
Really? well that is good to know and it would explain why I got so much trans fluid out of the transmission. So, you think that is where the coolant was going and I am on the right track? I had a hard shift into second gear just before I noticed this as well as was thinking they were related.
mal81394
Oct 25, 2015 08:29 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
