transmission dipstick broken!
Hi,
after reading the other posts about trans. fluid I went to check mine for first time (108k miles, bought it at 84k), found the dipstick, pulled it out and the bottom half is broken off. I don't think it happened just now, but its possible.
a) if it did happen just now and the bottom half fell into the trans is that bad or will it get caught somewhere down there and not cause a problem?
b) where if possible can i buy a new one?
c) how in the meantime can I check the fluid color?
THanks.
THanks.
Broken dip stick
I broke mine in my 2003 C70 a while ago. I could not find anything the would fit and grab the brolen part. I tried the long finger tool but it would not open when in the tube.
The tube has one bolt that can be reach from under the car and one O-ring. After removing the tube the broked part was there sticking out of the tranny hole. I had to order a new stick so I ordered 2 sticks.
NOW... as I was changing fluid and I would be checking the stick for a while I made a temp stick out of a long plastic strap. I just transferred the markings and wrapped tape at the stopping point for proper measurment.
Any questions please ask.......
Cb
Cb
bcolins
2001-2013 model year V70
10-28-2013 10:55 AM
