Used 5w-20 instead of 5w-30. Is this OK?
Old May 13, 2018 | 07:21 AM
peterz54's Avatar
Default Used 5w-20 instead of 5w-30. Is this OK?
Like an idiot I pulled the synthetic 5W-20 (Used in daughter's car) off my garage shelf and put it in my 2001 S60 2.4L turbo.
Weather in Florida is turning hot in afternoons. Will this be OK? Normal oil is 5w-30.
Thanks
Old May 13, 2018 | 08:08 AM
the larger number refers to the viscosity at high temperature - 20 being thinner than 30. Given you are in a warm climate, I'd drain and refill with the correct weight (no need to change the filter if you have only a few miles)
Old May 13, 2018 | 10:42 AM
CookieTheSwede's Avatar
If you live in Florida, only use 10W30 in your S60.
ycartf
May 6, 2013 11:19 AM
J Dubb
Feb 24, 2010 04:51 PM
yoyomai
Dec 14, 2009 07:08 PM
axelm
Aug 29, 2008 05:30 AM
Marks 240
Sep 23, 2005 11:30 AM
