What would be a symptom of ball joint failure?
If you can get down there and get a hold of the lower control arm and pull down, it would move if it was bad, or use a pry bar between control arm and steering knuckle. Is it maybe a upper spring seat??? Did you take a 21mm wrench to the upper strut nut, under the hood, and if it turns more than 360, it needs one.
volvobacon
10-11-2005 09:11 PM
indagutter
10-11-2004 07:10 PM
