windows- drivers side - reset procedure
Old Aug 17, 2010 | 05:00 PM
KATIE1000's Avatar
Default windows- drivers side - reset procedure
alternator went bad, battery died, now window on drivers side won't go up or down.... what is the reset procedure???
Old Aug 18, 2010 | 01:38 PM
patsfn2's Avatar
first thing that needs to be done is check and make sure you don't have a blown fuse....if your window was working then all of a sudden stops, it's very possible that a fuse could have blown...if not they it could be either the window switch itself or if not the switch then the window motor/regulator...hard to really say but I would check the fuse first...then use meter to test switch if fuse is fine to see if you have voltage flowing through the switch...then if that test fine through process of elimination I would think that you would have a bad window motor/regulator...start with the easiest hope this helps!!!
mjohnny
Mar 18, 2013 02:35 PM
ToledoVolvo01
Apr 30, 2010 09:34 PM
mmlco
Aug 31, 2009 05:31 PM
typhoon55
Sep 9, 2006 12:59 PM
pcgold
Jul 26, 2006 08:40 PM
