1998 S70 GLT Transmission will not engage
Old May 10, 2017 | 12:40 PM
cardana24's Avatar
Default 1998 S70 GLT Transmission will not engage
Hey guys,
I just bought a 1998 s70 GLT with an automatic trans that will not engage. I can put the car into gear and it will move slightly forward or reverse then it acts as if it goes into neutral. The engine will then rev freely and the car will not move at all. I already have another trans to put in the car, but I want to make sure it is not something silly before I take the time to swap the trans out. Has anyone ever experienced this? Thanks for any suggestions and help.
Old May 12, 2017 | 08:05 AM
Psaboic's Avatar
Check the fluid level and see if it is ok. Actually it would not hurt to change the fluid out with the correct type.
Old May 12, 2017 | 08:08 AM
cardana24's Avatar
The fluid level is fine and it does not smell burnt. I have no clue what fluid is in it, but I assume it's the proper fluid.
Old May 25, 2017 | 03:16 PM
s70godlol's Avatar
id check your clutch, it might be burnt and you might need a new one
Superdave741
Sep 9, 2018 09:22 PM
worledl
Jan 31, 2012 11:06 AM
volvo740Owner
Nov 21, 2008 07:16 PM
