1998 s70 no start severe backfire no codes??
Old Jun 24, 2014 | 10:19 AM
garysvolvo's Avatar
Default 1998 s70 no start severe backfire no codes??
Have a 1998 s70 non-turbo. 90,000 miles.
Timing belt has been changed and looks good.
New dist cap old one was broken split in two places
New rotor
Compression between 160-180 all cylinders
Turns over good and fast with out plugs.
With everything in place it turns over and then severely backfires. No start.
Any help would be appreciated.
Old Jun 24, 2014 | 01:58 PM
pitrow's Avatar
my first guess would be that the timing belt didn't get put on correctly.
Old Jun 27, 2014 | 01:24 PM
kwatt's Avatar
Did the backfire start happening after you replaced the distributor cap? If so, you have spark plug wires wrong. If the timing belt was on wrong you would have bent valves and hear the valves tapping to top of the piston
Old Jun 30, 2014 | 01:37 PM
garysvolvo's Avatar
Default BAckfire
Turns out water in number 3 cylinder.
Tj Wagenknecht
Jun 11, 2013 04:26 PM
DrHicks
Oct 21, 2011 01:43 PM
rotho
Jun 10, 2010 06:56 AM
TERRY940
Oct 27, 2008 05:19 PM
biffo19
Jul 21, 2007 09:08 PM
