2000 S70 door check repair
Old Oct 9, 2013 | 08:00 PM
topkat418's Avatar
Default 2000 S70 door check repair
Hi all any suggestion as to repair the drivers side door check? Door loosely swings open and will crease fender if not repaired previous owner indicated it needed to be welded thanks
Dan
Old Oct 10, 2013 | 09:25 AM
geemurphy's Avatar
Dan,
All you need is this and time to install it...without welding. It bolts in. http://www.fcpeuro.com/products/volv...-v70-9187591-1
Greg
Old Oct 10, 2013 | 04:50 PM
pitrow's Avatar
Originally Posted by geemurphy
Dan,
All you need is this and time to install it...without welding. It bolts in. Volvo Door Check Front (850 C70 S70 V70) Genuine 9187591OE | FCP Euro
Greg
If the previous owner indicated it needs welding then it's probably that the mount has cracked and just adding a new check will work for a while, until the whole thing rips out of the door pillar.
This is a typical problem on these, do some searching around, there's a few threads on fixing it.
Mine has the same problem btw. My driver's door was clicking loudly when opened or closed and I thought it was the check, so I bought a new one. After taking it apart, the original check was fine, but the mount in the column has cracked, so putting a new check in won't do a thing. I haven't had time to get it welded yet so I just live with it and remember to keep a hold of the door when I open it.
Old Oct 10, 2013 | 06:18 PM
geemurphy's Avatar
Well said...not previously aware of this condition.
Cheers! Greg
rspi
Dec 11, 2015 07:28 PM
vol740wa
Jun 12, 2015 05:02 PM
LITTLESTHOBOUK
Jan 16, 2012 07:56 PM
abelyear
Oct 12, 2011 01:49 AM
jpirish
Dec 5, 2010 11:12 PM
