98’ s70 t5 manual/ car will not accelerate past 2.5k rpms
Old Aug 16, 2019 | 09:39 AM
  #21
Psaboic's Avatar
Originally Posted by FromTheFar
Alright folks she up and running! Changed the O2 sensors and misfire disappeared. Buuutttt i have a bad acceleration sensor so that should be the final issue!
Kinda weird that the O2 sensors caused the issue, especially without throwing a code, but hey, I'm glad it is running and great job sticking with it. Lots of folks would have said the hell with it.
Old Aug 25, 2019 | 09:10 PM
  #22
FromTheFar's Avatar
Default Update ( not good)
Alright so everything is replaced and working great! But after 50 miles with new acceleration sensor; the car stats sputtering at about 1/4 throttle! This car loves my wallet more than me im going to check for vaccum leak and there is no check engine light!
Old Aug 25, 2019 | 11:51 PM
  #23
Psaboic's Avatar
Do you still have the old part? If so, put it back in and see what happens. You may have gotten an new part with a defect.
Old Aug 26, 2019 | 12:55 PM
  #24
FromTheFar's Avatar
No i threw the old one away! But i did check diagnostics via obdll and i says im getting “closed loop using O2 sensor for fuel mix”! Im clueless as to what closed loop is but will do research. Also no check engine light! Also im sorry this is taking forever to fix this issue.
Old Aug 27, 2019 | 03:54 PM
  #25
firebirdparts's Avatar
Closed loop means it's running based on the O2 sensors. That is not possible on initial startup, and it my not even be desirable at WOT. If some sensors aren't believed, it may set a code and run based on a fuel table calculation. Some of the S70's will run with the MAF unplugged, and they run well, so evidently there is also a backup fuel table too.
It has some options for calculating how much fuel it decides to squirt in there.
Old Dec 7, 2019 | 06:39 PM
  #26
FromTheFar's Avatar
Default Final update: Very ridiculous
Folks this is the final update! Thank you to everyone and all the help. I did a vaccum leak test today and found that the pipe connecting to the turbo (directly) would leak air AND sometimes wouldnt! I dont know how the car did not throw me codes! I did drive it HARD this monday and it drove fine! Then this wendsday it started to act up again, ALSO it still had no check engine light! I will be getting a new RIP kit and replace all piping! Again thank you to everyone!
descortes
Sep 29, 2017 01:44 PM
rspi
Mar 26, 2014 09:19 AM
thekoopa
Apr 1, 2011 12:14 PM
cmstar
Jun 9, 2010 01:40 PM
billybob420
May 2, 2010 01:31 PM
