Are the 98 and 99 instrument cluster/speedometer interchangable ?
Old Feb 22, 2011 | 08:44 AM
malushi3's Avatar
Default Are the 98 and 99 instrument cluster/speedometer interchangable ?
i have a 98 volvo s70 and i need a new speedometer,
i found one but its a 99 and im not sure if it'll work for my car.
I notice that where the fuses are for the 98 its these cirlce things on the 99.
Please help
Old Feb 22, 2011 | 08:50 AM
dj_puffe's Avatar
is yours with a trip computer info? if is see if the other one has one if not everything else will work except that info
Old Feb 22, 2011 | 11:43 AM
malushi3's Avatar
yeah it does have the trip computer, but my other question is will a light or warning come up if i change the speedometers because i know some cars do ?
thanks again
Old Feb 23, 2011 | 10:39 AM
dj_puffe's Avatar
From what i know from 1998-2000 are interchangable. so is like plug and play, no lights should come on. Mine is a base v70 from 1998 and i purchased fog lights, switches for front fog lights and for the trip info from a 2000xc found at the junk yard and the relay for the fog lights from a 850 dont know the year found at the junk yard too. Everything was plug and play. The dash bord cluster with trip computer info i found some info to a store and asked them if it match my car and they told me cause it work except the trip info if i dont have the switch. so now i will go back to the junk yard and take that cluster and put it in. If you can wait few days i can be 100% sure about all this.
Old Mar 28, 2011 | 01:06 PM
mark_disfree's Avatar
I have heard that 98 is different from 99-00. You can tell which ones are later production easily: The 99-00 say "MAX" on the fuel gauge instead of "18" on the 98's.
I saw this on another volvo forum as well "You'll have either 18 or MAX as the "full" indication depending on whether you have a Motronic 4.3 (pre-'99) or CAN ('99-'00) cluster."
That said, its possible that a 98 may fit in a 99 or a 99 may fit in a 98 but will everything work correctly, probably not.
Old Mar 29, 2011 | 08:18 PM
malushi3's Avatar
are the miles going to stay the same if i change the speedo?
if they are im trying to stay as close to my real mileage as possible
Barbarella
Jan 1, 2016 10:39 AM
my'94 940
Mar 16, 2014 02:20 PM
cn90
Apr 24, 2013 01:18 AM
volvo5volvo
May 29, 2012 05:46 AM
akb1274
Aug 22, 2011 12:01 PM
