98 S70 Driver side window issues
Old Oct 8, 2010 | 06:07 PM
silverstreak98's Avatar
Default 98 S70 Driver side window issues
Hello everyone —
Problem: front driver side window acting up.
Description: started one week ago, had a couple hot days then - cool, very cool. When I power the window down, no problem... when i go to raise the window, after it raises up past the halfway mark, the window starts to pitch down on the front end while still raising up...till closed.
It squeaks a little as it raises up as if it was too tight ? After its all the way up I have to pull it flush into the top part so its sealed. Funny thing, it rained and I opened and closed it no problem.
What gives ?
result: I lose about about 5-10 degrees off level.
See picture of illustration to see what I mean about it being off pitch... Areas circled in yellow.
I would appreciate any feed back, tips and diy techniques as I am low on cash...
Thanks in advance.
Bruce
Old Oct 8, 2010 | 08:01 PM
gdog's Avatar
Something in your window lift mechanism is loose and/or about the let go; time to take the door panel off and see what's going on....
Old Oct 9, 2010 | 07:08 AM
Thx,
That much I guessed, any resources you might point me to for panel removal, possible parts replacement resources...
Bruce
Old Oct 9, 2010 | 12:25 PM
Usually this starts with noise. On older cars, it's a good idea to lube the tracks, etc. as soon as you start hearing noise. Pull the panel and check the tracking mechanism for damaged plastic tracks, etc.
Old Oct 10, 2010 | 07:25 AM
I'll try that route - appreciate the tip. I'll post feedback on whether it works or not.
Now I'll to find out what kind of lube... how to get it into the tracks.
Help with panel removal or would that be in the manual ?
Old Oct 10, 2010 | 01:59 PM
Probably one screw near the handle, remove the lock **** screw, maybe a screw behind the speaker grill and the rest will be pulling it loose from the door. Be careful with the buttons, they may just pull out as well.
carolvc
Sep 10, 2014 07:49 PM
rjb44
Aug 27, 2010 05:12 AM
hosey82
Aug 5, 2007 06:59 PM
charlesbattaglia
Jan 19, 2006 11:09 PM
florida98s70glt
Mar 20, 2005 01:04 PM
