98 s70 steering rack
Old May 21, 2009 | 08:26 PM
philsmall's Avatar
Angry 98 s70 steering rack
I am in the middle of replacing steering rack 98 s70 T5 does anyone have any tips on how to separate coupling / u joint from steering wheel shaft to the steering rack without disassembling the car? Any help would be greatly appreciated.
Old May 21, 2009 | 08:28 PM
You have to work it out. Did you try opening the slot some already?
Old May 21, 2009 | 08:32 PM
philsmall's Avatar
Right now I'm just looking at it wondering where to go with the rack left, right dont know. Can I loosen the other side of the couplin from inside so I can slide it up?
Old May 21, 2009 | 08:37 PM
Once the subframe is hanging down the rack should be suspended till the coupler comes apart.
Sometimes an angled screwdriver pushing the center shaft out works.
Old May 21, 2009 | 08:42 PM
philsmall's Avatar
Sub frame hanging down? I might be over my head with this one, how do I accomplish that?
Old May 21, 2009 | 08:47 PM
In order for the steering rack to come out the rear if the subframe needs to be dropped down quite a but to get it out.
You would have to support the motor and drop the subframe in the rear.
Old May 21, 2009 | 08:52 PM
philsmall's Avatar
Definitely not what i was hoping to hear but I'll give it a go thanks so much for the help!
Old May 21, 2009 | 08:55 PM
Your welcome anytime.
Old May 22, 2009 | 08:17 AM
philsmall's Avatar
Question Drop sub frame
Tech,
I'm working in my garage and a little cramped, how exactly do I drop the sub frame w/o killing myself? would I be separating the body from the frame? I guess my question is; since I'm not on a lift do I put jack stands under the sub frame and lift the car/body up and away to gain the clearance I will need?
Old May 22, 2009 | 09:23 PM
I would try to make sure you have 2 floor jacks. Use one to hold the motor in place. Then use the 2nd one to drop the subframe slowly till you can get the rack out.
Old May 23, 2009 | 06:33 PM
philsmall's Avatar
Question center mount
Tech,
Got the old rack out and the new one roughly in position however I'm having a line up problem, the whole rack apppears to be too far forward on the sub-frame. Is the center mount symetrical? I didn't look close when I when I removed it and the only thing I can think is that the stud which goes through the sub-frame is off center and I have it in backwards. Kind of had enough for today maybe I crawl under tomorrow and every thing falls into place. Thanks for all the help.
Old May 23, 2009 | 06:41 PM
You have to mess with it and work it into the holes as you put the subframe back up.
Loosen the bracket for the center stud so it moves some and get the rack in then tighten the bolt back up. That might help some as well.
Old May 24, 2009 | 07:25 PM
philsmall's Avatar
Tech,
Car is back on 4 wheels after a few cuts, bumps and bruises, I hate the u joint and the location of the lines but it is 90 % done. I have one last question for you, tomorrow morning I am going to bleed the system then take for alignment how ever I am a little conflicted as to what fluid to use. When this odyssey started I changed the pump I knew in my heart it wasn't the pump but it was easy and when I went to NAPA for fluid they sold me the CFH 11S (green) $21.00. The pump and the rack both came with what appeared to be tranny fluid in them and the system also appeared to have trans fluid, so my question is what is the correct power steering fluid for a 1998 S70 T5? Once again thanks for the help!
Old May 24, 2009 | 08:21 PM
The 98 is ATF the 99 and up used the 11S.
Old May 24, 2009 | 08:31 PM
philsmall's Avatar
Dextron III???
Old May 24, 2009 | 08:34 PM
Yes that is fine.
Old May 25, 2009 | 06:45 PM
  #17
philsmall's Avatar
Car steers fine but shop wouldn't do alignment due to shot lower right ball joint part is on order will replace when it's delivered any tips on control arm replacement?
Old May 25, 2009 | 06:46 PM
  #18
That is a cake walk I did mine today in about 20 minutes total.That's including removing the tire.
Old May 29, 2009 | 10:02 AM
  #19
philsmall's Avatar
Well its not a piece of cake for me the strut extended and now nothing will go together any thoughts? Got it, done, thanks again!
timmins
Sep 28, 2022 02:00 PM
maduko
Nov 21, 2011 09:03 PM
redbriq
May 5, 2011 10:40 PM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
