ABS/Trac off light???
Old Jul 12, 2006 | 09:43 PM
Lawbrum319's Avatar
Default ABS/Trac off light???
Changed rear brakes on Saturday morning. Thanks to here and VolvoSpeed, went very well. I'm sure you mechanical types are very impressed. Anyway, on the way home from the office today my ABS and Trac off light just suddenly came on. Of course I have no idea what is going on. Car feels 100% the same. Brakes working same. Please someone give me a clue. Surely tech or another equally impressive data bank of knowledge person can help me out.
Thanks.
Old Jul 12, 2006 | 10:01 PM
Default RE: ABS/Trac off light???
ABS module is most likely bad.
Old Jul 12, 2006 | 10:24 PM
runitforever12's Avatar
I have had the same problem for 20k. 98 s70 ar at 146k. Mechanic says $688 to fix. He also said I could live with it. Suggestions?
Old Jul 12, 2006 | 10:33 PM
ORIGINAL: runitforever12
See Your post I put in a link to get it rebuilt.
Old Jul 12, 2006 | 11:47 PM
S70ismyfriend's Avatar
yeah i had this same problem your abs module went bad if you look around you can find a used one for a lot cheaper then what they charge at the dealer i got mine for like 160 with a pump attached
Old Jul 13, 2006 | 04:01 AM
Lawbrum319's Avatar
What do you guys think of the people on Ebay that are garages and tehy will rebuild the mdule, test it and tehn return to you for installation? They claim the codes do not need to be reset after the fix. Plus, how easy is it to get the module off and back on? I'd much rather spend around $100 rather than $700 to fix this problem.
Thanks again
Old Jul 13, 2006 | 12:55 PM
Lawbrum319's Avatar
Here is the scoop now. COme out today and the lights are no longer on. I tried to drive quick and hit brakes hard and the ABS is working fine. Is it possible when I changed my rear brakes that I may have caused an error to show up that fixed itself? Everythign is working fine, so I'm not messing with it. However, for future reference, would you still consider sending the ABS module to one of the places that advertises that they will fix it and send it back for installation over buying a new one?
Thanks.
Old Jul 14, 2006 | 09:18 PM
Alot of the places that rebuild them have Really good luck fixing them.
The reason your lights come and go are because the unit shorts out sometimes and other times it doesn't.
It will cost you about $5.00 to $10.00 for the Set for the socket you need at an Auto Parts store to get the module off.
Is it turbo or Non-turbo?
Old Jul 14, 2006 | 10:14 PM
Lawbrum319's Avatar
It is a 1998 S70 T5. So you suggest going ahead and sending it off for repair? The ABS is working. You know your stuff though, so tell me what I need to do, and I'll do it. Thanks for your help.
Old Jul 14, 2006 | 10:30 PM
You will need to get the socket for it. It looks like a Female torxes.
I think it is a E5 or E6.
Then remove the Air filter box. Then under the ABS pump you will see a Black Box. It has four screws going form the bottom up into the Alimunium. Undo the 2 plugs first. The Big one feel for a tab on the back side by the small plug. Push the Tab in and lift the outside cover of it to unlock the plug. Then remove the small plug.
Then remove the 4 screws and you will have the module in your hand.
jbuck
Jan 14, 2013 10:50 AM
dragonwingvolvoc70
Aug 22, 2011 08:00 AM
gabyman97596
Dec 23, 2010 08:59 AM
gabyman97596
Apr 23, 2009 07:20 PM
mcj
Sep 13, 2006 08:21 PM
