AC flashing lights
Old Aug 21, 2009 | 08:56 PM
Sthacker70's Avatar
Default AC flashing lights
Hi all,
I noticed that when I first start my car up that the A/C off button and the recirc flash orange for a few seconds before stopping. A/C seems to be working fine. Anyone ever experienced this?
Thank you
Old Aug 21, 2009 | 09:00 PM
Somthngfrce's Avatar
That means that the Ac unit control has stored (fault) codes. Pull the codes and that will tell you the fault ( or weak link) in your AC system
Old Aug 22, 2009 | 07:03 AM
Sthacker70's Avatar
How do I pull the A/C codes? I recently had to see why the check engine light was on but it was unrelated to the A/C.
Old Aug 22, 2009 | 07:39 AM
You need to find someone with a scanner to read the A/C codes. It might be as simple as the interior temp sensor fan being seized. It is located on the dash to the right of the steering wheel. You will see like little vents by the switches on the dash. Using a flashlight look in there and turn the key on. See if the little fan inside starts spinning when the key is turned on. If it does not you can try cleaning it with some compressed air.
Nathan007
Oct 2, 2014 06:32 PM
mrlament
Jan 12, 2008 09:05 PM
jasonc
Aug 30, 2006 12:34 AM
Sailing_Mike
Nov 6, 2005 12:23 AM
dave_n_s
May 17, 2005 11:06 PM
