AC & Recirculation Air Lights Flashing
Old Oct 14, 2005 | 04:46 PM
Sailing_Mike's Avatar
Default AC & Recirculation Air Lights Flashing
Hello,
I am new to this and need some help here.
I have a 1996 850 GLT Wagon with 101,000 miles on it. The LED next to the AC selector and the LED next to the Recirculating/Fresh Air selector flash 18 times in unison after starting the the car. What does that mean? It happened for the first time this morning.
Thanks,
Mike
Old Oct 14, 2005 | 10:19 PM
Default RE: AC & Recirculation Air Lights Flashing
It means there is a fault in the climate system.
You need to have the codes pulled from it to see what is wrong.
Old Nov 3, 2005 | 02:21 AM
swede850T's Avatar
Tech,
How do you pull these codes? Mine just started flashing too.
Thanks
Old Nov 3, 2005 | 08:23 PM
You will need an OBDII scanner that reads the climate module.
Old Nov 5, 2005 | 06:38 PM
swede850T's Avatar
OK, what kind of trouble do these faults lead to? As of right now, other than the blinking, there are no problems. The heat, the defrost, all that works great.
Is this usually a big deal?
Old Nov 6, 2005 | 12:23 AM
It could be as simple as a motor out of adjustment. If everything is working you should be fine for now.
Sandman
Feb 17, 2017 06:18 PM
Jaide
Jun 8, 2015 05:56 PM
2007xc90
May 9, 2014 02:09 PM
ohowie
Feb 14, 2010 10:25 AM
deathbots
Jul 22, 2007 05:36 PM
