Amsoil
Old Oct 6, 2013 | 08:34 PM
RA082324's Avatar
Banned
Default Amsoil
I have 7qts+ of AMSOIL 10W30 left from my previous car (new) never got to changing it before it died...now I have my S70 and I know that's the right weight. I am wondering, AMSOIL doesn't have EA filters for my car but they recommend WIX...I remember reading about getting a filter with an anti-return Valve..MANN which makes Volvo...but all I see are cartridges OR a Wix with an Anti-Return valve (WL7124) which is a canister type (not a cartridge)...what should I use?
Also, is this what I've been hearing about? Preferable?
http://shop.advanceautoparts.com/web...erm=oil+filter
Old Oct 6, 2013 | 09:18 PM
Wix makes a good filter. Not sure if that Mann issue applies to the 2000 models.
Old Oct 7, 2013 | 07:39 AM
kwatt's Avatar
Whatever you do, don't get a Mobile 1 filter.
I destroyed the oil filter cap trying to get it on and then off when I couldn't get it tight. The prior oil change it went to a shop for the oil change. They put it on so tight I couldn't get it off and had to break it. I bought a new cap. Could not get it to spin on past the O-ring. Bought another cap. Same problem. Bought another filter, end of problem with the same cap.
The Mobile 1 filter uses a rubber lip to seal it top and bottom. They come off, but I didn't trust it at that point.
Old Oct 7, 2013 | 01:47 PM
RA082324's Avatar
Banned
Mobil 1 oil is crap, I wouldn't use their filters either. So the wix canister is ok? I ask this because I notice everything else is a cartridge. Also, how do you think this would hold up with AMSOIL over a 6 month to year period? Obviously my first change isn't a year, you have to do 3 consecutive to be safe to use it for one year...but I used to use their AMSOIL EA filters, which they don't have for this car.
Old Oct 7, 2013 | 09:18 PM
kwatt's Avatar
As far as I know you can only use the cartridge. Really, why would you not use the original cap? Wix makes a cartidge to fit.
FlyingVee
Sep 29, 2013 10:40 PM
znerajr
Engine & Internal
Jan 3, 2009 01:01 PM
HummerGuy
Oct 14, 2008 07:51 AM
proudmonkey
Aug 28, 2007 01:33 PM
