Bad Wheel Bearing?
Old Nov 10, 2005 | 12:05 AM
alecw81's Avatar
Default Bad Wheel Bearing?
I've been getting quite a bit of noise from the drivers front wheel for about 5k miles. At first I thought maybe it was the new tires I just put on, but after putting 5k on them and having them rotated the noise is still there. There is also a slight bit of vibration felt in the pedals and wheel, which made me think that it could be the rotor, but usually if the rotor is warped then you really notice it under braking, and I don't get any more vibration or noise under braking. The noise is speed dependant, which has led me to believe it's a wheel bearing or something in the suspension possibly. Any ideas Tech?
Old Nov 10, 2005 | 12:35 AM
Default RE: Bad Wheel Bearing?
I would say wheel bearing as well. I will also bet it starts at about 40 to 45 MPH.
It would be either wheel bearings or tires but if you have new tires then I say wheel bearing.
Old Nov 10, 2005 | 01:10 PM
dcox612's Avatar
Same thing happened on mine after new tires, turned out to be the right front wheel hub assembly. That fixed the problem once replaced. Been having the same problem with the left side now, so I ordered another front wheel hub ***. to fix it.
Found one on Ebay for $95 plus shipping NEW...should be here Friday or Monday. I have about 91K on my s70 now and both have gone bad.
Old Nov 10, 2005 | 03:44 PM
alecw81's Avatar
May I ask why you bought a whole wheel hub assembly? You can usually just have the old bearing taken out and have a new one pressed in.
Old Nov 10, 2005 | 09:29 PM
They only come as a assembly. It just screws into the back of the hub assembly.
Old Nov 10, 2005 | 11:21 PM
alecw81's Avatar
That's pretty retarded, when a wheel bearing went bad on my Talon I just had a new bearing pressed in.
Old Nov 10, 2005 | 11:40 PM
Yes it is kind of retarded but it only takes about half of the time to install then having it pressed in.
Old Nov 11, 2005 | 12:14 AM
alecw81's Avatar
And costs a lot more... $115 is the cheapest on EBay
Psaboic
Jun 18, 2011 11:36 AM
Chupa517
Jul 14, 2009 07:35 PM
chef
Jan 23, 2009 11:22 AM
jeremy4130
Oct 26, 2008 04:26 PM
GaMax2k1GLE
Jun 13, 2007 02:24 PM
