brake dust
Old Sep 7, 2010 | 10:24 AM
kennedy759's Avatar
Default brake dust
2000 S70 turbo, there seems to be a lot of brake dust on my wheels, is this normal with volvo brakes or has previous owner replaced the pads with cheap auto zone pads?
Old Sep 7, 2010 | 10:40 AM
txs70's Avatar
cheap pads.
do they make noise?
Old Sep 7, 2010 | 11:16 AM
Meloyler's Avatar
Smile cheap pads?
I have a 99 S70 T-5, (only 86K miles), and the front wheels always seem to have a ton of brake dust after a 'bath,' and about a week of driving - I've had her nearly 3 years, and I figure I am about due to replace them since up to now, there hasn't been any squeal......now there is...........any thoughts on good pads, w/o going to the dealer? Thanks!
Old Sep 7, 2010 | 03:12 PM
jks2's Avatar
Volvo pads are notorious for dust. I switched to Akebono Euro Ceramic pads on my S60 and my sons 850. Stop just fine, no squeal and most importantly NO DUST!
Old Sep 8, 2010 | 09:03 PM
kennedy759's Avatar
I was thinking of buying wagner pads from o-rileys, anyone know if wagner makes pads for volvos? If they do, anyone tried them, I have had real good luck with them on my other vehicles
Old Sep 11, 2010 | 01:01 AM
donf's Avatar
Volvos ARE phenomenal brake dust producers!
Best product I;ve found is "Armour All Wheel Protectant".
Really clean the wheels first and it works great. I had mine off once and treated the inside also.
I am not a big fan of Armour All but this product is pretty good.
FWIW, your rotors are only slightly harder than a Belgium waffle. You really should replace them when you replace the pads.
Old Sep 11, 2010 | 04:53 PM
Welcome to Volvo ownership. Brake Dust!!!
Old Sep 11, 2010 | 08:18 PM
xxblindxx's Avatar
haha my wheels are always covered in them, switching to black wheels soon! will fix that issue some
Old Sep 11, 2010 | 08:27 PM
kennedy759's Avatar
sounds like the solution is to replace rotors and pads with after market, harder rotors and harder pads, or will this screw up the braking?
Old Sep 12, 2010 | 04:59 PM
www.IpdUSA.com has a set of pads that give off less brake dust. They brake just as well as oem's. Try that but remember, wheels & tires are on the ground, they will only stay so clean.
air force rascal
Oct 9, 2008 03:24 PM
opal45
Sep 1, 2008 12:12 PM
jks2
Mar 25, 2008 09:36 AM
casique
Jan 9, 2007 03:14 PM
Madoco
Jul 27, 2006 12:19 PM
