turbo??
Old Sep 1, 2010 | 09:20 PM
kennedy759's Avatar
Default turbo??
how do you get the turbo to kick in? while coming home from work I was in some back road hills with no traffic and finally felt the turbo kick in as I hit it to get up the hill, and the next one also, I could hear and feel it, seems like it does not spool up in stop and go traffic or on the freeway. I guess that is why my mpg is 26.4 average. This is my first turbo, I am use to big american iron, olds 442, and firebird formula(350 corvette) and my mercedes 560sl. any thoughts
Old Sep 1, 2010 | 10:59 PM
turbo matt's Avatar
Well you should be able to hear it. Should sound like a whistle or air being sucked like a vacuum cleaner. Try this to launch your car...turn traction control off...Left foot apply to brake peddle...right foot hit the gas peddle...probably half to 3/4 throttle. Hold car with brake (in drive) and steadily apply gas peddle...you are doing what is called loading the engine (do not allow the car to move forward)...once you start to hear the turbo spool (whistling/whirrling/sucking sound) immediatly release brake peddle (let off) and press the gas peddle to the floor all at the same time and let the trannie shift itself!! You car should launch from a dead stop with some gusto!! Possibly with some smoke screaming from the tires.! Depending on the torque converter forthe S70 T5 you should be launching with about 2-3 psi
Now only do this if your car is in good shape but this should get you out of the hole (dead start from a dig) and get the jump on the guy next to you. Once you get the technic mastered it is a whole lot of fun. You need this extra PSI on the launch to get these heavy cars moving!!
Old Sep 7, 2010 | 08:06 PM
What setting do you have the preformance switch in? Drive with it in S (sport) mode. It will kick in a lot more. The E (economy) mode limits the speed of the car. On that LPT (GLT), it doesn't take much to launch the car. Just switch it in S mode and punch it.
Old Sep 7, 2010 | 08:39 PM
kennedy759's Avatar
no performance switch, 2000 S70 GLT se
Old Sep 7, 2010 | 08:49 PM
The 2000 cars adapt to the drivers driving habits.
If you get on the gas somewhat hard you should hear the turbo.
Old Sep 7, 2010 | 10:46 PM
xxblindxx's Avatar
Can you explain that a little more?
with s70's ??
Old Sep 8, 2010 | 06:58 AM
All of my '90's model Volvos have a preformance selector near the gear shifter that allows me to choose how the computer and transmission operates. W (winter) S (sport) E (economy) modes. I can choose the setting and drive with it. Rather nice. I didn't know they stopped putting that in the S70's after my '98 model.
See item/page 72: https://www.customers.volvocars.com/...0_069.htm#pg72
Old Sep 8, 2010 | 07:06 PM
kennedy759's Avatar
I do have a button for winter, but nothing for sport or economy
Old Sep 8, 2010 | 08:35 PM
I think the winter button starts the car in 3rd gear. No low end torque. Yuk!
Old Sep 10, 2010 | 12:37 PM
elcs70's Avatar
your not gonna hear alot of turbo with a stock car. but if you wanna feel it, just floor it and dont stop til 140mph
Old Sep 10, 2010 | 12:54 PM
xxblindxx's Avatar
hahaha
Old Sep 11, 2010 | 01:08 AM
donf's Avatar
I can feel my turbos pretty well and without a bucnh of work on my part- turn key
step on gas
go like hell
repeat often.
There is a little "turbo control device" that may be malfuctioning on your car.
Old Sep 11, 2010 | 07:26 PM
kennedy759's Avatar
turbo control device?
Old Sep 12, 2010 | 05:07 PM
If you really want to hear your turbo, do what some guy did in Tulsa... He put some kind of megaphone on his turbo and drilled a hole in the firewall of the car just behind the turbo. Man it sounded like someone had real live big horses loose in the car. You could hear the turbo breath and everything. The first two times I punched it I had to let off the gas it was so shocking. Funniest test drive I ever did.
1Gray760T
Nov 13, 2009 08:19 PM
