a/c not working
Old Jun 9, 2007 | 08:38 PM
danocox's Avatar
Default a/c not working
when I turn on the a/c nothing happens. I have repaired some lines and then put 1.6 pounds into the system. it holds presure and when i jump the compressor clutch wire it kicks on and the presure drops and it gets cold like it should. I read other threads and jumped the connector on the low side near the firewall, nothing happened. I then saw a switch near the low port and pulled it off I jumped some of the wires and the compressor kicked on but only for a second then turned back off.
any help or direction would be much appreciated. thanks
Old Jun 9, 2007 | 08:46 PM
Default RE: a/c not working
There should be a relay in the relay box under the hood.
The reason the compressor came on from the one switch is because you jumped the high pressure switch but since there is 3 prongs in the switch it also needs to see the cooling fan on which is the other prong on the switch.
Try grounding the connection at the low pressure switch by the firewall.
If it comes on then it is either a relay or the connections at the relay.
Old Jun 9, 2007 | 10:00 PM
danocox's Avatar
well I tested the relay and it works. when i plug the switch at the high side the clutch kicks in and the fan comes on but the clutch stays on for about a second junping the switch does nothing and the relay works fine. does the relay have a circut protection on it.
any other ideas because im stumped
Old Jun 9, 2007 | 10:55 PM
Did you try checking the ground at the low pressure switch like I said to?
The S70 system works with the low pressure switch grounding the system.
The 850 works the opposite.
Old Jun 10, 2007 | 07:01 PM
postdoc99's Avatar
Tech,
Please help, I have similar problem with AC. The AC worked last summer, although it leaked slowly.I had toadd one can of R-134 in two weeks or so. This summer, the compressor would not kick in at all. I could make make the compressor kick in byshortcutting low pressure sensor plug. I wanted to force the compressor to suckR-134 this way, but it did not work. Is the compressor shot? Where would you recommend to start to fix AC? I am committed to fix it substantially this time. Thank you!
Old Jun 10, 2007 | 07:02 PM
postdoc99's Avatar
...forgot: mine is 1998 S70 T5
Old Jun 11, 2007 | 09:29 AM
danocox's Avatar
the ground is good and nothing happens if I manualy ground the plug. if I unhook and plug back in the high side it will run but only fo a few seconds. I think it might be something with this plug or on the high side. the relay is ok, but if it has a circuit protector in the relay then the clutch could be drawing to much energy or something. I am stuck and I realy dont want to just start throwing parts at it so any info would be great. thanks
Old Jun 11, 2007 | 05:41 PM
ORIGINAL: postdoc99
Tech,
If you jumped the low pressure switch and it will run then it must still be to low or the low pressure switch is bad.
Old Jun 11, 2007 | 05:42 PM
ORIGINAL: danocox
Are you 100% sure the relay is good?
Try jumping the relay connection and see if the compressor comes on.
Old Jun 11, 2007 | 09:14 PM
danocox's Avatar
this is only geting better. now I have no power to the relay. where does it come from? I jumped the relay and I am sure that it works. I had power before and now I dont, this is so screwy! when i jumped the relay the same thing happened when removed and then pluged the high side back in rapidly, the comp would come on for about a second. if I did it fast enough it would stay on, but now that i dont have power I cant even do that. my check engine light is on but I think that is from removing the fuse to the A/C
help
Old Jun 12, 2007 | 05:40 PM
If the check engine light is on there might be a code stopping it from coming on.
I will have to try to get a copy of a wiring diagram and check it out.
Old Jun 13, 2007 | 07:46 PM
danocox's Avatar
sorry the power comes from the climate conrtol and the diagnostic conection it was blown. the same problem is with the high side switch so not new info other than the fuse. the presure on the low side drops to 30-37 so I think it is all working well I just cant figure out why the high side would be causing problems.
Old Jun 14, 2007 | 05:42 PM
Maybe the high pressure switch is bad.
I would really need to see the car to help much more.
I will still try to get the wiring diagram for you though.
Been buys at work and Boss hanging around alot.
Old Jun 15, 2007 | 06:18 PM
What year is it?
If it is a 1998 I have a diagram.
The 99 and up is to light in the computer program to get it printed out.
Old Jun 19, 2007 | 02:08 PM
danocox's Avatar
it is a 98 and i am wondering if there is something wrong somewhere else. becaue it does the same thing when I jump it with the wire. I dont know what to do now In lost.
Old Jun 19, 2007 | 05:43 PM
I can get you a 1998 diagram it might be easier to e-mail you with it.
If you want it PM me with your e-mail address.
Old Jun 21, 2007 | 05:10 PM
  #17
danocox's Avatar
is the safety and the high switch in the same place? if not where is it?
Old Jun 21, 2007 | 05:46 PM
  #18
The high pressure should also be the safety.
Old Jun 21, 2007 | 11:37 PM
  #19
danocox's Avatar
is there any other relay that could be messing up? someone mentioned a relay behind the glove box.
Old Jun 23, 2007 | 07:25 AM
  #20
The one behind the glovebox is for the Fan speed. Some say it will stop the compressor from working but I have never seen that.
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
kerry
Oct 24, 2012 08:58 PM
BigAdam
Oct 21, 2008 10:01 AM
