Car still hesitating!
Old Dec 9, 2010 | 07:35 AM
hunterw0026's Avatar
Default Car still hesitating!
After the car is warmed up, it hesitates in a weird way.
NO CHECK ENGINE light has come on, so at this point I can't read the code. So I am working blind.
My boyfriend changed my the mass air flow sensor and it didn't help at all (suggested to him by a Volvo mechanic).
Where to now? Would a bad plug not set off the check engine light?
Old Dec 12, 2010 | 05:34 PM
Vmax's Avatar
bad plugs don't trigger a check engine light.
check all the vacuum lines, all the intercooler hoses for hairline tears (if its a glt or t5), go real slow and check each and every hose like you're looking for gold. if your spark plugs are old, change them, if your wires are old, change them, distributor cap & rotor are old, change them. old fuel filter, change it.
start with checking all vacuum lines first. remember, go slow and check every detail.
after you've done all that and it still hesitates, change your pcv system. good luck!
Old Dec 14, 2010 | 07:18 AM
Talking Was mass air flow sensor all along!
Went to Advanced Auto and got the computer code read.
Was mass air flow sensor all along.
So, fixed, solved, this is why the car was hesitating.
Solved!
Thanks everyone!!!!!
Old Dec 14, 2010 | 10:02 PM
loudgoldwing's Avatar
what "computer code" would an OBDII scanner pick up re: the MAF Sensor, but not be serious enough to trigger the "Check Engine" light?
Lisakochanik@gmail.com
May 30, 2012 07:40 AM
SIMAUD
Oct 16, 2009 09:03 PM
Kaspir
Feb 16, 2009 08:44 AM
buzzbomb
Jun 9, 2008 04:10 PM
magak2572
Feb 9, 2008 10:31 AM
