Changing Engine
Old Apr 6, 2009 | 08:39 PM
chas svensen's Avatar
Default Changing Engine
And I sure would like to have someone be my friend and adviser as I go through the process. I am working with a 1998 S70 . Have picked up a used engine w/123K and good comp. Before we even start I have two issues.
1.The engine is listed as from a V7O but everything seems to indicate it will fit.
2. I believe that the air pump is different, in that it has a gismo located on the firewall side of engine with tubing coming out of the exhaust manifold whereas this is not present on broken engine. Different ECM ? Will adjustments become obvious when I get into it? Will I need to change the ECM?
Hopefully I can get this under way in short order and find some knowledge here.
Old Apr 6, 2009 | 09:48 PM
The motor should fit fine.
Use your parts from your car only. Don't use those parts from the new engine.
As long as you use your parts like that you will not need to change anything.
Old Apr 6, 2009 | 10:07 PM
so use my old exhaust manifold or plug the hole in the replacement?
Old Apr 7, 2009 | 07:51 PM
I would use your old exhaust manifold.
gorillajin
Jun 10, 2010 09:01 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
thullz
Nov 30, 2007 11:11 AM
Frank88
Jan 17, 2005 12:14 PM
timbo
Oct 27, 2004 09:27 PM
