Changing turbo control valvle
Old Mar 15, 2009 | 02:13 PM
BlazeS70's Avatar
Default Changing turbo control valvle
I've got a '98 S70 GLT and I'm planning to replace the turbo control valve this week since I'm off on Spring Break. It sounds a bit straightforward, but is there anything I should know/be wary of?
Old Mar 15, 2009 | 02:20 PM
sRed70's Avatar
Same here. Got a 0243 code and need to change the tcv. Where did you order your part from.
Old Mar 15, 2009 | 02:23 PM
BlazeS70's Avatar
My dad got it from ipd. My dad and I are changing it for routine maintenance/because we want to...I have the code for an EVAP leak...which we're also going to deal with.
Old Mar 15, 2009 | 03:58 PM
It is as straight foward as it looks. Swap one hose at a time.
Old Mar 15, 2009 | 04:59 PM
sRed70's Avatar
Is the Ipd tcv that much better than this one...
http://www.eeuroparts.com/Main/PartD...spx?id=9155936
Old Mar 15, 2009 | 07:26 PM
sRed70's Avatar
Another question tech....Ipd recommends a boost gauge with the tcv. Do I really need to buy the boost gauge. I would like to have but moneys tight and i just want the car to run.
Old Mar 15, 2009 | 07:36 PM
BlazeS70's Avatar
I'm not sure if ipd's is better...but I've found ipd to be very reliable.
Old Mar 15, 2009 | 07:39 PM
sRed70's Avatar
Yea I just order the Ipd tcv. Never had a bad experience with them and I trust their products so I order the tcv, 3 clamps and 7 ft of hosing.
Let me know how your install goes.
Old Mar 15, 2009 | 10:10 PM
BlazeS70's Avatar
I will, thanks.
Old Mar 16, 2009 | 11:53 AM
sRed70's Avatar
How much did the tcv cost you? Ipd website says $89.00 but they only charged me $67.00 for it?
Old Mar 16, 2009 | 02:55 PM
BlazeS70's Avatar
I honestly have no idea. My dad got the TCV for me for my birthday.
Old Mar 17, 2009 | 07:57 PM
If you really want a boost guage there is better looking ones than the IPD ones.
I hate the looks of the VDO one.
Old Mar 23, 2009 | 09:19 PM
sRed70's Avatar
OK so I installed my Tcv from Ipd and it wasn't to bad. Took me about 2 hours...I also replaced the hoses with the ipd silicon hose. It wasn't to hard but the hose on the turbo compresser was a PITA. It took me about an hour to get that piece on and it would have been easier if I had a lift but I dont. So overall pretty easy just that one hose was hard.
kanthony30
May 27, 2015 12:54 PM
Shawnv
Jul 23, 2011 05:49 PM
aruizdelhoyo
Jan 22, 2009 04:46 PM
KINGI5T850
May 30, 2006 11:02 PM
