Cracked Strut Cap
Old Nov 29, 2010 | 01:14 PM
amacchia's Avatar
Default Cracked Strut Cap
New to this forum, traded Land Rover Disco II for 2000 S70. My trusted indie mechanic wants $225 per side to replace cracked strut caps. I'm pretty handy and caps are inexpensive but I'm a little leery of compressing the springs if I pull the struts, plus the cost of an alignment. Question is: can I just replace the strut caps with the struts and mounts left in place on the vehicle?
Old Nov 30, 2010 | 12:36 AM
gdog's Avatar
If by "strut cap" you mean the front upper spring seats, then no, you can't replace them "in place". It's like any other macpheson strut assembly; you'll need spring compressor and air tools, plus an alignment when you're all done too.
Old Nov 30, 2010 | 03:58 AM
amacchia's Avatar
Upon closer inspection, what appears to be "cracked" is the top of the strut mount as labeled in illustration. The rubber is worn away so the strut cap (as labeled) is contacting bare metal. I thought I could just replace the cap with strut in place, but I think you are right, I will have to remove the entire strut. Thanks for the quick response.
nhadoulis
Mar 2, 2014 10:03 PM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
jimatqsi
Aug 26, 2007 01:13 PM
go2sharks
Jun 2, 2007 11:00 AM
OverTheTop
Nov 30, 2005 11:56 PM
