Crank No Start.
Old Jan 25, 2021 | 04:12 PM
  #21
Oilinmycoffee's Avatar
Hey!
I am trying to get this car fixed and appreciate your help. Its sitting, and I've been using another car. Explains why nothing has been done as of yet, plus online school and work. So. I am back to ask you of your knowlege: " Would it still be the fule pump relay if I got a lil flame when I tried to start it after spraying gas into the manifold?"
I heard nothing when I jump the pump relay's post facing each other. But I will do it again. I did it from the front seat. I will have some one turn to ll position while I listen from the rear passenger tire hub. Also, I will check the other relay, fuel injector relay near the fan housing shroud, to see if it is working. Not sure how but will research it.
Thank you for passing on what you know.
Old Jan 25, 2021 | 05:58 PM
  #22
Originally Posted by Oilinmycoffee
Hey!
Easy, check compression, measure fuel pressure with a gauge, Use a $5 noid light to check injector pulse!
Skinny C. Williams
Oct 16, 2018 07:45 AM
venkman
Dec 11, 2015 08:35 PM
albert89
Aug 2, 2013 06:08 PM
slimflex2
Mar 13, 2012 02:59 PM
white out
Oct 20, 2008 07:05 PM
