oil leaking on to exhaust
Old Jan 24, 2021 | 10:33 AM
thewhitegorilla's Avatar
Default oil leaking on to exhaust
I recently bought an s70 its pretty nice as far as they go, but initially everything was fine and then after a few minutes on the interstate I noticed a oil burning smell, and a little bit of smoke coming from the rear on the engine. I had a similar problem with my 850 and the flame trap coming through the engine wall was plugged and the tubing was shot. I wonder if I am at the same place again, Plugged and causing pressure blowing out a little bit of oil and hitting the exhaust. Any pertinent replies are welcome. Its 20 degrees out so I probably am no going to tackle it today, I just want to get ready. First step is wash everything really good with degreaser while cold to see if I can see exactly whee its coming from.
Charles
Old Jan 24, 2021 | 10:47 AM
The oil cap seal can leak, fills up the waffle under the spark plug cover, and leaks out of the divot in the rear of the top of the head onto the exhaust manifold. If there's oil on top of the head a few dollar oil cap seal might fix it.
Certainly a clogged pcv system makes things worse
Old Jan 24, 2021 | 11:45 PM
Psaboic's Avatar
Ditto what Hoonk said!!
Old Jan 25, 2021 | 08:54 AM
if its a turbo, it could also be a turbo oil return line seal. there's no $.10 part that can make more of a mess :-)
Old Jan 28, 2021 | 05:37 AM
Its a normally aspirated, It set a code, IDK if its related, but I have been busy and now its snowed about 4 inches maybe this afternoon Ill get out there and read the code, thank ti all who posted and I will update when I find out whats going on.
Carloscda
Volvo C30
Mar 30, 2020 09:33 AM
Popeye75bm
Nov 18, 2013 09:26 AM
oneelkarcher
Feb 12, 2012 06:17 PM
tetsugen
Dec 16, 2011 04:13 PM
Mary108
Feb 17, 2008 12:51 PM
