CV BOOT REPLACEMENT
Old Jun 6, 2008 | 07:59 AM
rmclemns's Avatar
Default CV BOOT REPLACEMENT
I'm replacing the CV boot on a 1998 Volvo S70 automatic on the passenger side. I replaced the drivers side a couple years ago.
I'm at the point in the Chilton's Manual that says "remove the bearing cap, and pull the shaft out of the transmission". What is a bearing cap and how is it removed since there are no pictures of this in the manual?
Old Jun 7, 2008 | 08:38 AM
Default RE: CV BOOT REPLACEMENT
That is the bracket that bolts to the motor to support the axle.
There is 2 12MM bolts holding the outer bracket to the inner bracket.
Old Jun 26, 2008 | 01:04 AM
BigAl's Avatar
How difficult and what would it cost to do this? I was replacing my brakes several hours ago and discovered grease everywhere around the front passenger side. It was the boot, a slit about 1/3 through.
Thanks in Advance
sjrider
Sep 11, 2010 08:48 PM
rickderman
Nov 3, 2009 09:58 AM
texschell
Apr 14, 2008 08:47 AM
daddyrod
Feb 7, 2007 11:41 PM
