CV JOINT
Old Mar 3, 2008 | 10:03 PM
htowncourier's Avatar
Default CV JOINT
Hello,
I was putting new tires (Michelin Harmony's) on my 1998T5. The tire guys said I needed a new CV joint. I looked, and sure enough the boot cover is gone, and it looks like grease is bleeding out. I plan on fixing this ASAP, but first I have a few questions-
1. When replacing CV joints it looks likeit is better to replace the whole axle assembly.
2. Should I replace both CV joints at thesame time?
3. Can I do this myself - (with no experience and limited knowledge)
4. What other parts may need/be easy toreplace when having the CV joints replaced.
Thank you
Old Mar 3, 2008 | 10:21 PM
Default RE: CV JOINT
I would just buy a rebuilt axle and install.
If you were to do it your self you would haev to buy some tools. The Axle nut is I believe a 36MM.
Old Mar 3, 2008 | 10:39 PM
Thanks Tech.
I do have tools, Im used to Chevy and I have never done CV joints.
What would I expect to pay someone to replace - I assume it is best to replace both at the same time
Old Mar 3, 2008 | 10:43 PM
If you just replace the axle that will include both joint on one side.
The axle should be able to be located for less than $100.00 for each axle(Each side)
Some will charge between 1 to 2 hours to replace.
Old Mar 4, 2008 | 03:08 PM
Getting the axle assemblyreplaced for $185.00 ata local shop
FYI - Dealer wanted $473 just for the part.
Old Mar 4, 2008 | 06:22 PM
Cool
Old Mar 5, 2008 | 08:45 AM
JimKW's Avatar
Is $185just for one side? Sounds like a good price to me.
dpvovo
Feb 18, 2019 07:41 PM
tepuy
Sep 7, 2005 08:54 PM
jcmartin
Jun 25, 2005 11:49 AM
floryed
Apr 10, 2005 12:23 PM
indagutter
Oct 11, 2004 07:10 PM
