Dash Lights On
Old Mar 13, 2010 | 10:27 AM
creviston's Avatar
Question Dash Lights On
I have a 98 S70 and the ABS/TRACS ON/SERVICE CHECK ENGINE lights are on for about 10 minutes or so and then go off. Sometime they dont go off at all. Upon reading a few articles, it seems the ABS control unit is bad. Am I diagnosing this correct? Any info on this would be greatly appreciated. Thank you.
Old Mar 13, 2010 | 10:57 AM
spaded09's Avatar
Your abs unit is probably shot, you can get it fixed cheap. Service light comes on every 3000 miles to remind you to service engine and you have to reset it via obd ll. Have you scanned to see trouble codes yet?
Old Mar 13, 2010 | 11:15 AM
creviston's Avatar
Thanks for the info. No I havent did any scans as of yet. What exactly is the obd ll
Old Mar 13, 2010 | 07:00 PM
spaded09's Avatar
Its under armrest. Open arm rest, take plastic cover off and you will see obd ii connector for scanner you plug into. You can go to autozone and they will read your codes for free or you can buy one.
Old Mar 25, 2010 | 08:44 PM
creviston's Avatar
Thanks I havent been on in awhile. I will check that out Thank you VERY much.
Old Mar 26, 2010 | 04:20 PM
buci's Avatar
Try this before buying a new abs module,sometimes it works,i wrote that article after trying it on several cars.good luck. http://www.carinstructions.com/volvo...70-abs-module/
Old Mar 29, 2010 | 11:12 AM
creviston's Avatar
Talking
Hey sounds good. Thanks I will try that tonight and post how it went.
Thanks again!
Old Mar 30, 2010 | 09:59 AM
cn90's Avatar
I doubt that will work.
Anyway, I had this problem in 2007 and replaced with a rebuilt ABS Module from bba-reman.com for $115. LT warranty.
So far so good.
Old Mar 31, 2010 | 07:54 AM
creviston's Avatar
Well it was worth a shot. Nope, didnt work. Y ea I seen a few places that will rebuild them from $70.00 - $150 bucks. Im gonna pick one up at the junk yard first for 20 bucks, might get lucky and actually be a good one. If not I will have it repaired. Thanks for your guys inputs.
Ratphink120
Mar 11, 2022 10:41 AM
mikwik
Oct 22, 2011 05:42 PM
zloetakoe
Aug 27, 2011 02:06 PM
850GLE
Sep 22, 2009 10:28 AM
tr_car_nut
Jan 19, 2008 09:37 AM
