engine missing
Old Sep 15, 2010 | 04:57 PM
kennedy759's Avatar
Default engine missing
2000 S70 turbo, I was at a stop light and the engine started to miss, and continude all the way home no check engine light, turned it off, and restarted ok, any ideas?
Old Sep 15, 2010 | 05:19 PM
xxblindxx's Avatar
i would have to say a coil.. if its not missing that bad it wont show a code (or that's my experience)
Old Sep 15, 2010 | 06:15 PM
Did you hook up a code reader? Sometimes the cel is slow to come on or blown.
Old Sep 15, 2010 | 06:25 PM
kennedy759's Avatar
mechanic friend also said coil, but with out cel, only way to tell which one is to replace one at a time. I did smell fuel, while at idle, like unburned fuel coming out of exhaust.
Old Sep 15, 2010 | 06:30 PM
xxblindxx's Avatar
check connections first..
i had 3 coils go in the past 2 months, the first coil was completely dead and a code popped up right when it went bad but for the other 2 it would only miss at about 3,000 rpm's and for one it took about 2 weeks for a code to show and the other one never even gave a code..
kinda sucks because it would be nice to know what cylinder is missing..
Old Sep 16, 2010 | 07:39 PM
kennedy759's Avatar
check connections everything was fine, except a lot of the plastic loom over the wires going to the coils, is broke and missing. anyway started car up to to giggles wires to make sure none were broke or grounding out, didn`t find anything but the good news the cel came on, so now I can find out which coil is bad.
Old Sep 17, 2010 | 01:09 AM
xxblindxx's Avatar
Well that's good! some people say its better to replace them off its they are old getting old but then it also runs about $250 haha..
but my last one that went out, i replaced it with IPD's HD coil.. "supposedly" give a better spark? haha
http://www.ipdusa.com/Volvo-S70V70-1...-128-372-5862/
Old Sep 18, 2010 | 12:31 PM
kennedy759's Avatar
code reader and coil came in the mail today, code reader says misfire on #2, replaced coil, fixed it
Old Sep 22, 2010 | 11:34 AM
roketa's Avatar
Which/where did you get your "Code Reader"?
Thanks
Old Sep 22, 2010 | 08:00 PM
kennedy759's Avatar
got the $59 one from idp, real simple to use
taz0001
Oct 15, 2021 10:43 AM
tommy byrd
Mar 5, 2012 05:18 PM
vinnyman72
Jan 30, 2011 08:25 AM
mpez
Nov 17, 2009 08:37 PM
bumblebee03
Sep 8, 2005 11:39 PM
