Engine Mount (RH Lower under crank pulley) bolts...
Old Sep 5, 2006 | 01:38 AM
Reilly_S70GLT's Avatar
Default Engine Mount (RH Lower under crank pulley) bolts...
I just got a new engine mount to replace my old on due to it's bad condidtion. When doing so three of the four bolts snapped... So of course I need new bolts.
However I'm not sure what size the bolts are, in terms of grade and length. I know the top two are 14mm and the two going into the frame are 17mm.
Anyone know what kinds of bolt i need?
My car: '98 Volvo S70 GLT
The part just for refferance:
Image from eEuroparts.com
Old Sep 5, 2006 | 06:08 PM
elbert's Avatar
Default RE: Engine Mount (RH Lower under crank pulley) bolts...
I would get them from the dealer. Although it may cost a little more, it will save you time from tracking it down from different sources. It is likely you may have to do some cutting of the bolts to get the lenght that you need. Other sources may have the size and length, but they might not have the hardness of the metal to spec.
Old Sep 5, 2006 | 08:57 PM
ORIGINAL: elbert
I would buy get them from the dealer. Although it may cost a little more, it will save you time from tracking it down from different stores. It is likely you may have to do some cutting of the bolts to get the lenght that you need. Other stores may have the size and length, but they might not have the hardness of the metal to spec.
+1
ZaphodBblbrux
Jul 2, 2012 09:54 PM
toaoemerald
Jan 24, 2012 11:24 PM
guest01
Nov 5, 2011 10:11 PM
rmjryost
Nov 14, 2009 03:07 PM
cheesenacho
Jun 23, 2009 02:39 AM
