Engine upgrade questions
Old Dec 30, 2008 | 05:14 PM
Tarlok's Avatar
Default Engine upgrade questions
Background my 99 S70 AWD has 150k miles on it but still runs like a tank. I was wondering if it would be cost effective to do an ecu, exhaust, intake upgrade? I was also toying with the idea of maybe acquiring a S60R engine and trying to swap it in. I know that will prolly run more than the upgrade kit but due to the mileage on the block and such it may be better in the long run.
I found a upgrade kit online for $1700 or so that would push hp to around 254 hp and 305 torque.
Thanks in advance.
Old Dec 31, 2008 | 07:34 AM
Default RE: Engine upgrade questions
I would do the upgrade to the motor you have.
As long as it was taken care of pretty well you should be fine.
Old Dec 31, 2008 | 09:44 AM
S70driver's Avatar
Just do the "upgrade kit". I bet your speaking of the one from EuroSportTuning (EST).
I would highly suggest looking into piece mealing all the parts, just to compare.
Why? Because sometimes a local shop that can mandrel bend can make you a downpipe and catback system for less then what you can buy prefabbed.
spankey
Mar 28, 2016 09:10 PM
Phil 850
Jul 25, 2012 10:01 PM
90240DLGA
Aug 1, 2009 12:25 PM
S70driver
May 15, 2006 05:02 PM
willko1
Jan 15, 2006 02:11 AM
