Heater Hose Kit
Old Jan 13, 2009 | 10:51 PM
christopherallen's Avatar
Default Heater Hose Kit
Need the hoses as my heater is disconnected. Anyone know a good place to buy the top and bottom hose for 1998 Volvo S70 GLT? Does it matter if turbo or not? Mine is.
Old Jan 14, 2009 | 07:26 AM
Default RE: Heater Hose Kit
Did they just disconnect the hoses and put a small one between the metal pipes?
You might not really need the hoses.
If you do look here.
http://www.fcpgroton.com/product-exe...category_id/66
Old Jan 14, 2009 | 12:17 PM
Thanks, cheapest prices I have seen
You mentioned I might not need em? My enginge was leaking coolant like crazy out of those hoses in my 850, I suspected this was why the engine was overheating. Now I have a car that just has em disconnected? It seems like that just could have been done before.
My question is why do you say I might not need them? My heater will not work without them it seems ? Does not get too cold here as I am in College Station, Texas
Old Jan 14, 2009 | 12:19 PM
Alot of times the heater core leaks and someone bypasses it. When they bypass it they just remove the aluminum part of the hose at the firewall and stick a piece rubber hose in to join both parts of the aluminum hoses together. If they did that on the bypass you might just be able to connect the hoses back to the firewall.
FuzzyMan21
Feb 16, 2015 03:36 PM
guest01
Jul 25, 2014 08:41 AM
ycartf
May 6, 2013 11:19 AM
SkyVolvo
Aug 8, 2011 12:33 AM
S70driver
Apr 22, 2006 03:45 PM
