How to: change oil lines?
Old Nov 26, 2009 | 06:51 PM
BlazeS70's Avatar
Default How to: change oil lines?
Anyone know of a good write-up of how to change oil lines?
Old Nov 27, 2009 | 06:44 AM
I do not know of any but it is really not all that hard.
Old Nov 27, 2009 | 04:12 PM
BlazeS70's Avatar
True. I see the two oil lines and where they go...but what is the easiest way to remove them?
Old Nov 27, 2009 | 04:19 PM
Easiest way is to drop them out the bottom. The hardest thing is to get the 10MM screw out of the front of the motor. Even harder getting it back in.
You will also make a little bit of a mess doing them so keep a drain pan close.
Old Nov 27, 2009 | 10:44 PM
BlazeS70's Avatar
Forgive my ignorance, but uh...what 10mm screw? I thought all you had to do was get those really annoying clamps off to take the hoses out.
Old Nov 28, 2009 | 06:33 AM
No there is a 10MM bolt that goes into the front of the motor. If you look at your new lines you will see the hole where the screw goes.
Volvo_1997
Oct 18, 2009 12:37 AM
burnferris
Mar 17, 2009 08:23 PM
dcarlson12
Oct 27, 2008 12:18 PM
ludeless
Jun 29, 2006 10:09 PM
