Intermittent Stalling
Old Aug 14, 2013 | 10:05 PM
Texnmidwest's Avatar
Default Intermittent Stalling
I have a 98 Volvo S70 GLT 98K miles. Great car. Runs well except for once or twice a day I will be idling and the engine will die like I just turned off the key. It starts up eagerly when I turn the key and then runs fine for a while. If I am moving it usually happens at slower speeds and the tach will drop then go back up to where it should be. I am guessing that it cuts out then restarts. Like I said it doesn't cough, spit or sputter afterwards or before nor is it hard to start. It just acts like a gremlin shut the key off just to mess with me!
Where should I start looking for the problem?
Old Aug 17, 2013 | 06:24 AM
OK, well, now it is getting hard to restart after it stalls. The only way I can restart it after it stalls is to depress the gas pedal a little and crank it. I am thinking that tells me the problem lies in the fuel system. I think I will stop by a place that can do it and have them check the codes. Check engine light comes on now.
Old Aug 17, 2013 | 06:43 AM
That's where you should start, the CEL.
Also check this video:
Old Aug 17, 2013 | 08:49 AM
Thanks you!!!!! I will do that!
Old Sep 11, 2013 | 06:04 PM
Well, here is an update. I changed the relay. Ran for about 1.4 miles then quit....dead.....wouldn't start up again. So, I had it towed to a Volvo certified mechanic near me. He ran the codes and found that it was a bad MAF sensor. So far so good. Car is running. I an cautiously optimistic!
What bums me is that I can get this part for less than 100 bucks and this shop charged me 200 bucks for the sensor. I don't mind a mark up on parts. A shop has to make a living. But double priced?
Thanks for your advice!
Old Oct 26, 2013 | 07:44 PM
Ralphy11's Avatar
Hey guys and gals, new here. We've owned a 2000 S70 since new. Had the same problem since today. I just replaced the plugs, smoothed... is that a word? Smoothed out down shifting idle and all.
Ralph11
geofftucker
Jan 1, 2009 08:21 AM
dads 740 turbo
Oct 20, 2008 07:43 AM
srhode
Jan 8, 2007 08:37 PM
w.schoen
Jun 21, 2006 01:58 PM
