Just got my '98 s70 glt - lots of q's
Old Apr 26, 2007 | 06:00 PM
  #221
S70driver's Avatar
Default RE: Just got my '98 s70 glt - lots of q's
7 PSI is a good amount of pressure. Our tiny little 13g's can only handle about 15 PSI before they are out of their effeicency range. Anything above 15 PSI and it is worthless on a tiny 13g turbo. That is when you swap to a 16T turbo and run 15-17 PSI. The 16T can handle the 15PSI better then the 13g can.
Old Apr 26, 2007 | 06:09 PM
  #222
samadkins29's Avatar
sooooo, you would say its better that I get that pvc hose on the barb? it really is tough as hell though, it supposed to be able to withstand more than 30 psi.I am not sure I cna even get it on all teh way, jsut lack teh strenght. I have an idea, maybe Ill hood up everything using teh vac connects, then ahve someone rev teh engine to see if it leaks. Bascially the alternative route for em would be easier, only question is can it withstand 7psi, I wont be turning up teh turbo anytime soon. Unless, does teh speed tuning chip increase teh psi of teh turbo at all?
Old Apr 26, 2007 | 06:27 PM
  #223
S70driver's Avatar
Just get it on right.
Old Apr 26, 2007 | 06:36 PM
  #224
man, thats gonna be hella hard to get on, lol
Old Apr 26, 2007 | 07:11 PM
  #225
S70driver's Avatar
It obviously can be put on right, so figure it out.
Old Apr 26, 2007 | 07:27 PM
  #226
well, called prosport, the trick is to put the end of the tube in boiling water to heat up which will make it soft, then push in on the barb and let it cool
Old Apr 27, 2007 | 10:46 PM
  #227
hey, do u know the following color wires in a volvo:
ground wire color
12v (+) wire
Old Apr 27, 2007 | 11:52 PM
  #228
S70driver's Avatar
No sorry.
Old Apr 29, 2007 | 04:39 AM
  #229
well my ghetto gauge install is almost complete . Ill post pics when its dont so you can poke fun at me.
Old May 6, 2007 | 01:01 PM
  #230
well after much debating, looking around under the hood, and driving. I have finnaly decided to do the stage 0.
I plan to get the EST high flow filter, new o2 sensor, stylin motors vac line replacments, fix my strut mount, NGK spark plugs, and money allowing samco silicon hoses. Might add a few more things to the list. Basically I didnt want to do it at first since I had just go the car and didnt want to spend the money replacing stuff that was working. But I see now that doing the stage 0 is what is best for my car.
Old May 6, 2007 | 01:11 PM
  #231
S70driver's Avatar
ORIGINAL: samadkins29
Good good. I recommend the Stylin Motors turbo hoses instead of the SAMCO's. SAMCO has been in business a long time and make great products. Stylin Motors Inc. has been in business I don't know how long, but have just recently been making Volvo silicone turbo hoses. I love my kit from them and Sig is a great guy to deal with. I would go with them for both my silicone vaccum lines and silicone turbo hoses. It is helping a smaller company out that is now making stuff for Volvo's and it was well worth my money and it will be worth your money.
Old May 6, 2007 | 01:19 PM
  #232
hmm ok, they are the same price anways. on the 02 sensor, I should get front and back at the same time?
Old May 6, 2007 | 01:28 PM
  #233
S70driver's Avatar
Yeah I would get front and back 02 sensors at the same time. Then you know both are fresh.
Plus your doing STAGE ZERO. So they should be replaced.
Old May 6, 2007 | 03:03 PM
  #234
ok so I had some questions about stage 0:
Plugs, cap/rotor, plug wires: this what he is reffering to?
fuel pumps: how do you know if these are going bad or not?
clean injectors: by clean I assume he means to clean them and not replace?
clean IC/IC plumbing: ' ?
Old May 6, 2007 | 03:28 PM
  #235
S70driver's Avatar
1. Plugs, Cap/Rotos, Plug Wires. Yes that is what he is talking about.
2. Fuel pump, I can't honestly say how you can tell.
3. Cleaning the injectors meana cleaning the injectors. There are companies that do clean these and possibly your local dealership can clean these and or a local area garage can do the same. If you want to replace them go right ahead.
3. Cleaning the IC (Intercooler)/IC Plumbing (Intercooler Plumbing). Mean just that. Now I don't know how to clean these items. I believe there is a certain way to do so. Check over on Volvospeed for more info on that.
Old May 6, 2007 | 03:30 PM
  #236
ah ic, thanks
ima prolly try and pick up a chilton repair manual aswell
Old May 6, 2007 | 03:37 PM
  #237
S70driver's Avatar
ah ic, thanks
Or if you can find a HAYNES manual.
Old May 17, 2007 | 12:32 AM
  #238
ok, here's a question for you. When I drive my car, I usually only go up to 2-3k rmp in my regualr driving(which makes it go up to 10vac), so getting a BOV, would it still produce the blow off?
Old May 17, 2007 | 08:43 AM
  #239
S70driver's Avatar
You will only hear the blow off valve go off when your in boost. Which is the other side of the gauge.
Old May 17, 2007 | 09:37 AM
  #240
do u happen to know at what rpm the boost should be engaged?
