Looking for diag help 00 S70 trans issues
Old Jul 23, 2016 | 04:51 PM
njroma's Avatar
Default Looking for diag help 00 S70 trans issues
So I've happened across a very good condition 00 S70 that has a trans issue that I need some help diagnosing.
Issue: CEL on, flashing up arrow, i believe is stuck in 3rd gear.
I did have the codes read at autozone, they pulled 5
P1618 DTC in another control module
P0753 Shift Solenoid A Electrical
P0758 Shift Solenoid B Electrical
P0748 Pressure control solenoid A electrical
P0702 Transmission Control System Electrical
I did try a cheapo ebay code reader it pulled 1
P1618 TCM communication
Ive tried to clear it but it instantly comes back
I have tried to clean the contacts in the PNP switch with no change.
Im thinking this issue is a bad TCM or bad connection somewhere in the related wiring, I need someone more knowledgeable that I to point me in the right direction.
BTW it is a 2000 S70 GLT ( I believe ) AWD 2.4 Turbo AT 176xxx miles
Thanks in advance
Old Jul 23, 2016 | 06:35 PM
Psaboic's Avatar
Have you removed the TCM, checked the pins on the module, and connector, and then re-installed the TCM? Sometimes if the module is not seated properly it will cause issues.
Old Jul 23, 2016 | 07:01 PM
njroma's Avatar
Just got done doing that. Everything looked ok. No change at all.
Old Jul 23, 2016 | 07:43 PM
mrcharlie's Avatar
Not a trans tech, but the shift and pressure control solenoids are usually located on the valve body which can be accessed by removing the pan. Possibly there could be some damage to the wiring to the solenoids like chafing through to bare wires. It probably wouldn't hurt to drop the pan anyway to see if there`s any excess debris in there.
Old Jul 23, 2016 | 08:27 PM
njroma's Avatar
I will be getting to this soon, I can see that the fluid is pretty dirty, but not burnt.
REVOLV
Sep 10, 2017 11:46 AM
hikermtnbiker
Mar 17, 2013 10:27 PM
gotdurt
Mar 8, 2012 05:28 PM
volvamos
Jul 3, 2009 09:20 AM
1996850turbo
Jul 26, 2007 02:36 PM
