loosing coolant
Old Jul 31, 2010 | 07:10 PM
kennedy759's Avatar
Default loosing coolant
2000 S70 turbo, I have put 500 miles on and the coolant level in the reservoir has gone from max to min, any ideas where to look for problems?
Old Jul 31, 2010 | 07:43 PM
xxblindxx's Avatar
Do you see anything on the ground? if now i would pull the passenger side carped up and look to see if its damp down there.. heater core could be leaking..
Old Jul 31, 2010 | 08:19 PM
kennedy759's Avatar
no visable leaks, I will check the carpet, do these cars blow head gaskets?
Old Aug 2, 2010 | 02:31 PM
donf's Avatar
500 miles - since what?
a 2000 is ready for a heater core - check both sides.
If you just replaced fluid, hoses, or radiator you may just be having some trapped air working it's way out.
Old Aug 2, 2010 | 05:35 PM
kennedy759's Avatar
500 miles since I bought it, made sure the the fluid was topped off, don`t know when anything was changed
Old Aug 2, 2010 | 08:16 PM
kennedy759's Avatar
going to check if all the hoses are tight tomarrow
Old Aug 5, 2010 | 05:05 PM
tr_car_nut's Avatar
You may have a leak at the head gasket. But check under the overflow reservoir where the bottom hose connects to the tank. Hopefully you just have a bad rubber hose.
Old Aug 7, 2010 | 07:34 PM
kennedy759's Avatar
I think I found my leak, the hose under the tank was loose, it was dripping coolant, tightened the clamp about 3 -4 turns, will test it tomarrow, thanks tr-car-nut for your idea
Old Aug 8, 2010 | 01:02 PM
We had a leak in our S70 GLT. Turned out to the the resevior cap. It was split and cracked. $3 at U-Pull-I t.
Old Aug 30, 2010 | 07:42 PM
kennedy759's Avatar
fixed, it was the coolant tank, both hose connections were bad
cf11bluebird
Aug 12, 2017 10:56 PM
rspi
Jun 24, 2012 04:04 PM
91shelby
Feb 12, 2012 11:54 PM
endneu913
Jul 13, 2010 11:53 AM
vacuumboy
Feb 18, 2010 05:27 PM
