Lower arm control
Old Apr 7, 2009 | 05:38 PM
chachouu's Avatar
Banned
Default Lower arm control
What are the main symptoms of bad lower arm control or some other front end part.
my car has been shaking a little bit around 70MPH,and my passenger tire is losing outer thread,after about 8 months,I bought it new.
Old Apr 7, 2009 | 08:24 PM
Either you inspect tie rods or balljoints or have them checked.
Old Apr 7, 2009 | 10:29 PM
chachouu's Avatar
Banned
Tech would that be inner or outer Tie R.
Old Apr 8, 2009 | 03:41 PM
FredMc's Avatar
GET an alignment and wheel balance first.
Then report back. While they are doing the alignment and wheel balance have the rock the wheel hub back and forth and up and down. That may help pin point any suspension issues you have with the sway bar links, lower control arm (with ball joint) and tie rods.
since you are having a toe in condition it usually is tie rods but they will check it out for you.
Old Apr 8, 2009 | 04:49 PM
candodad's Avatar
To specifically answer your question, when my lower control arm bushings deteriorated, there was a distinctive single clunk in the front end on braking and accelerating. I could hear it and feel it through the steering wheel. Plus it felt like the car was shifting to one side very slightly, but only coinciding with the clunk. It does not sound like worn control arm bushings are the cause of your symptoms.
Old Apr 8, 2009 | 10:03 PM
s70_t5_1999's Avatar
mine was shaky like that and i ended up replacing both control arms and tie rods. topped that off with an alignment and it is all shake free now, and a lot quieter and tighter
Old Apr 9, 2009 | 04:44 AM
Default Hard Down Shift...
On the S70 that I recently picked up for my daughter I feel a clunk when I hit the gas and make it down shift. I can be going around 40 mph and hit the gas to pass someone and I feel a clunk as if the car shifted into a lower gear with a bank. Happens almost every time. Is that a symptom?
f8talh8red
May 21, 2009 10:30 AM
etype38
Oct 13, 2008 07:50 PM
sy381
Jul 2, 2008 07:33 AM
tech
Feb 21, 2008 07:52 PM
go2sharks
Feb 25, 2007 12:08 AM
