My volvo s70 Starts and dies need help!!!
Old Mar 11, 2012 | 04:32 PM
mohd_baig's Avatar
Default My volvo s70 Starts and dies need help!!!
Hello!
I have 1999 S70 with 188xxx miles on it; I recently had throttle issues with it, I took it to the dealer ship got it reprogrammed and it works fine i also got one ignition coil replaced; The car ran well for a week and now when i start it ; it starts and dies back. it takes me a few tries and then it starts back on. I would really appreciate if any one had any legit idea or information on it.
I dont want to take it back to the dealer and spend a fortune again, Unless it is necessary.
Old Mar 11, 2012 | 09:21 PM
Hi and welcome to the site.
Can you hear the fuel pump in the trunk area humming when you release the key?
Old Mar 12, 2012 | 09:46 AM
donf's Avatar
Maf ?
Old Mar 12, 2012 | 09:47 AM
kennedy759's Avatar
I just fixed this problem(knock on wood) on my 2000 S70, it was the immoblizer ring around the ignition.
Old Mar 12, 2012 | 07:14 PM
mohd_baig's Avatar
Default Re: Rspi
Hey thanks a lot every one for your feed back;
@ RSPI; i never heard that humming noise in this car. Or wear exactly do i have to hear the humming noise from. I know what the humming noise you are talking about because i had that in my old volvo 740 GLE. But not in my S70;
and i dont know a thing about MAF; like should i replace it or how do i know its bad.
And immoblizer ring... same i dont know . how do i find out if thats gone bad.
Thanks again everyone for your help and support.
Old Mar 12, 2012 | 09:09 PM
kennedy759's Avatar
When I had this problem the first thing I changed was the fuel pump relay, it is in the fuse box up by the windshield it is pink and has 103 stamped on it, you can get it at NAPA or order it on line at groton, that worked for me for awhile, than this spring same thing happened and a new relay did not fix it, so I bought an new immoblizer ring, it is in the steering column, and sits around the ignition switch, very easy to replace. fixed the problem
Old Mar 12, 2012 | 09:26 PM
when you try to start the car the fuel pump will turn on. When it fails to start the fuel pump should continue to pump gas for about 3 seconds. So, when you try to start, and let go of the key, you should hear the fuel pump whine for about 3 seconds. If you don't hear that your pump is likely not working. The fuel pump relay usually goes out more than the actually pump.
MAF = Mass Air Flow Meter.
Old Mar 12, 2012 | 09:34 PM
mohd_baig's Avatar
Default RE:
Thanks a lot once again; I forgot to mention one thing when i had my car at the volvo dealership they lost my keys and made a new one; so do you think that might be triggering the immobilizer ring.
lewis1022
Mar 11, 2013 12:47 PM
shaneds70
Jul 20, 2012 07:19 PM
Zhekka
Jun 29, 2012 02:42 PM
evrijm
Apr 3, 2012 11:30 PM
karutunian
Mar 13, 2010 08:11 PM
