Need Help
Old Sep 23, 2013 | 01:51 PM
1990_740Turbo's Avatar
Default Need Help
Ok where do I start. I have a s70 t5 It will start run for about 10-15 seconds and cut off. I've changed the flow meter fuel pump and relay still doing the same I haven't got to the ignition coil yet (msd) and I'm wondering if the turbo timer that I really don't need might be my issue. The speed sensor has also been bouncing around in my head as well. Any body think they might know before I start spending money on parts.
Old Sep 24, 2013 | 12:05 PM
What year is the car?
Old Sep 24, 2013 | 01:43 PM
1998 s70 t5 5 speed has me stressed lol.
Old Sep 24, 2013 | 06:39 PM
This may be a slight "lawn mower syndrome" issue. I suggest that you do a compression test. If the compression is low, put about 1 oz of oil in each cylinder and start it up then drive it around the block. Should reseal the pistons and keep it going forever.
Old Sep 24, 2013 | 06:41 PM
Will it restart each time and run for 10 seconds each time?
Old Sep 25, 2013 | 04:20 PM
Book well finally noticed that the crankshaft sensor wire was pinned behind the torque mount bracket pinching it between the head and bracket causing it to short out. I got the car started and running, drove it today. I have to change out the plugs still has a minor misfire. Overall it's running again after 3 days of searching.
Old Sep 25, 2013 | 04:22 PM
Thanks for the help @rspi
Old Sep 28, 2013 | 12:22 AM
gdog's Avatar
Oh Jeeeez; not LMS again!!
andrei3333
Dec 26, 2010 10:22 AM
Sanel30
Feb 18, 2010 09:16 PM
texan_176
Oct 4, 2009 10:05 PM
chef
May 19, 2009 05:57 AM
Svtfiveoh
Apr 15, 2008 06:51 PM
