Need some advise
Old Apr 4, 2017 | 08:30 PM
TurVo-Kid's Avatar
Default Need some advise
I have a 1998 Volvo s70 (The non turbo model, plan on putting one in) And want to get it as fast as I can,
1. How much hp can the stock block handle?
2. What do I need to do to surpass 15psi? (healthy without damaging the car)
3. any extra advise?
Old Apr 5, 2017 | 09:08 AM
I don't think the block is your weak link - check out Boxpin's signature (frequent poster on the 850 board) where his 850 has dyno'd to 403 HP at the wheels. If you plan on going over 300 HP, you will want to have a manual transmission, and a limited slip differential (ie a Quaife). Getting past 15 PSI boost will require 1) a bigger turbo (ie 18T or 19T) 2) a ECU tune - check our ARD's web site as a good example 3) a 3" downpipe and possibly a free flow cat/exhaust 4) consider high pressure tubing and other turbo boost controller bits as recommended by a blueprint design.
Old Apr 6, 2017 | 12:36 AM
TurVo-Kid's Avatar
Thank You! right now all I've done is put in a new air filter, and working on a new exhaust system right now. so far I only have a muffler delete and the exhaust pipe is cut off in the middle of the car. when Im done welding the system Ill install it. thank for your help. also being new to this forum, could you possibly send me a link to those websites?
Old Apr 6, 2017 | 05:12 AM
ES6T's Avatar
My advice would be to sell your car and buy one with a turbo amd then go from there.
Jesse54b
Canada, Over Seas & Elsewhere
May 19, 2015 10:44 PM
Lansdowne
Sep 22, 2014 01:02 AM
Jesse54b
Mar 22, 2013 08:18 PM
MattyXXL
Apr 13, 2011 04:39 PM
Volk
Apr 8, 2008 06:44 AM
