new tires
Old Nov 30, 2006 | 01:24 AM
slang925's Avatar
Default new tires
so I just recently got new tires for my volvo s70 awd sedan I got the falken ziex ze329
they seem pretty smooth on the road and through the curves I have only put 10 miles on them so we will see
but the wheel place said they couldnt do an alignment because of a loose right tie rod
I was skeptical, said it was $190 to repair, so I decided to pass on it tonight
if their are any reasons I should get my tie rod repaired asap let me know
thanks
steve
Old Dec 10, 2006 | 10:52 PM
elbert's Avatar
Default RE: new tires
If you have a bad tie rod, then this can be a safety issue for it controls your steering. One tire is not responding in tandem with the other side. It will also wear your new tire irregularly. Raise the side of the tire in question. Hold the 3 and 9 o'clock and wiggle. If you get a bit of play, then your mechanic is most likely on the level. If the $190 inlcudes alignment, then it is a fair price. You might as well have the other side for it may be going bad as well. You don't want to have to pay for another alingment.
gstake
Dec 15, 2014 02:47 PM
kwality
Nov 28, 2012 08:39 PM
a_ahmed
Dec 28, 2011 04:17 PM
dman777
Dec 25, 2011 11:18 AM
laf
Oct 20, 2006 10:42 PM
