No daytime running lights/headlights
Old Jul 15, 2007 | 08:25 AM
RPMCanes's Avatar
Default No daytime running lights/headlights
Fuses and relays seem to be OK. When I turn on the headlights, the rear lights and yellow marker lights come on, but not the headlights. When I hold down the high beam lever, they come on. Any Suggestions?
Old Jul 15, 2007 | 08:31 AM
Default RE: No daytime running lights/headlights
Try pushing in on the headlight switch.
The headlight switches break. It is a common problem.
Old Jul 15, 2007 | 09:43 AM
JAKESTERS's Avatar
NOTE: this may be covered under the recall, any certified volvo shop can replace this for free.
Old Jul 15, 2007 | 09:47 AM
S70driver's Avatar
Do you see a screw like object on the headlight dial? If so someone might have them turned off this way. Get a small screwdriver and turn it one direction and see if daytime running lights work. If not try the other way and see if they work.
Old Jul 15, 2007 | 08:26 PM
RPMCanes's Avatar
Pushing in the switch worked, but it would not stay like that. It's like it was spring loaded. I tried to turn that little screw to no avail either. Can anyone confirm whether or not there is a recall on that?
Old Jul 15, 2007 | 08:28 PM
RPMCanes's Avatar
If not covered, will the dash need to be disassembled to replace it? I certainly hope not...
Old Jul 17, 2007 | 05:46 PM
No the switch is like a 5 minute replacement.
NipZ
Oct 1, 2013 05:15 PM
jlewisinsyr
Aug 13, 2012 02:15 PM
mikwik
Oct 22, 2011 05:42 PM
NipZ
Mar 22, 2007 02:27 AM
GeoffC
Feb 21, 2006 07:06 PM
