Oil pressure light takes a while to go away
Old Apr 2, 2018 | 07:37 PM
first477's Avatar
Default Oil pressure light takes a while to go away
Whenever I do a cold start, the oil pressure light is always the last light on the cluster to go away. Usually it stays lit for about 3 seconds. Other than that it has no issues. It has 10w30 oil in it and the temperatures have been about 20-35 degrees fahrenheit, so not the ideal oil viscosity. Any thoughts? Also one time it was about 14 degrees out and I started it, and it made a terrifying sound. Then it sounded like the engine fan was running furiously, almost like when a school bus engine fan runs. It also has a slight squealing under the hood when cold. Once its fully warmed up it goes away. I think I’m going to have the timing belt, tensioner, and water pump replaced soon. Also there’s some oil leakage on the passenger side near the oil pan and under the timing belt area. Could this be a leaking camshaft or crankshaft seal? Any comments or advice would be appreciated.
Old Apr 3, 2018 | 08:52 AM
Psaboic's Avatar
First off, check the oil level. 10W30 is ok for the temperature range you mentioned. Could be some sludge buildup in the motor causing it an extra second or so to build pressure. What I would do is do an engine flush (get a can of motor flush at the store and follow the directions). Then change the oil and filter with a decent synthetic oil and go from there.
Old Apr 3, 2018 | 12:00 PM
first477's Avatar
Oil is full. I keep it topped of. I’ll try that motor flush. I only have 1000 miles on the oil that’s in it (mobil one high mileage synthetic) but it wouldn’t hurt to change it I guess. 5w30 is probably preferred in this climate because it never really gets over 75.
Old Apr 3, 2018 | 11:05 PM
gdog's Avatar
https://www.matthewsvolvosite.com/fo...ic.php?t=31236
Old Apr 4, 2018 | 08:08 AM
tony1963's Avatar
On a vehicle of this age, I would recommend removing the oil pan and having it cleaned in a spray jet at a local machine shop. While you send it for cleaning, remove and send the oil pickup pipe/screen as well.
There are O rings in the oil pan that can fail over time allowing a drop in oil pressure. The job will cost you a few hours and very little money. Here's an oil seal kit that we just bought for a vehicle:
https://www.ebay.com/itm/Volvo-S60-S...72.m2749.l2649
Old May 15, 2018 | 09:30 PM
first477's Avatar
Had cam seals replaced by a reputable mechanic (Independent Auto, Anchorage AK) and problem disapeared. Oil light gors out right away and slow oil leak has stopped.
Old May 16, 2018 | 10:28 AM
tony1963's Avatar
Cam seals will not impact the oil pressure. The pressure is made in the bearing and the seal just stops the excess oil from leaking out.
Old May 16, 2018 | 11:25 AM
firebirdparts's Avatar
I agree. The original problem is still there. The temperature around here has increased about 50F since your original post, so that may have helped it.
Old May 16, 2018 | 02:55 PM
first477's Avatar
Temperature might be making a difference, but something is definitely helping. I’m getting an oil pan heater installed so I don’t have as much of an issue when it starts getting below 20 because it hates being started and driven in that weather. I still might try the motor flush but I want to have the freshest oil possible come september, so I’m putting off the next oil change until then.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
Gabe Devries
Nov 23, 2016 09:20 AM
MattyXXL
Jul 14, 2011 05:12 PM
EricNR
Jul 6, 2010 08:23 PM
tech
Jan 30, 2009 06:18 PM
