Orange Dash Light Question
Old Jan 21, 2009 | 10:26 AM
`98_S70_T5's Avatar
Default Orange Dash Light Question
Hello everyone, this is my first post. I just recently purchased a `98 S70-T and I love it! It's comfy, it's fast and it looks great! I havea question though... There is a light on next to the speedo, it has a "snowflake" like look to it and sometimes a orangeish looking light is lit and other times it is not lit. At first I thought it turned on because the car was cold and then it would turn off once the car was warmed up. But it has come one when the car has been running for several minutes and I know that it's warmed up. Does anyone know what this light means?
Thanks!!
Old Jan 21, 2009 | 10:35 AM
Default RE: Orange Dash Light Question
That light comes on when the Temp is below freezing outside. It does that basically to let you know there is freezing conditions to be careful driving.
Old Jan 21, 2009 | 10:49 AM
`98_S70_T5's Avatar
Okay, great! Thanks for the very fast reply!
Also I am wanting to up grade my head and fog lights, do you have any recomendations for what works well with the S70?
Thanks again!
Old Jan 21, 2009 | 11:33 AM
Are you replacing the lights or just going to HID?
Old Jan 21, 2009 | 11:40 AM
`98_S70_T5's Avatar
I'm not sure yet. What would you recomend? What are the advantages of going to HID? My current lights look a little dim and my fog lights don't work well AT ALL in the fog.. I guess I mainly would like to have a much better set of fogs but also do not want dim headlights either.
Thanks for the input!
Old Jan 21, 2009 | 12:03 PM
Well you could either go to aftermarket projector headlights and get silver stars for the foglights.
But me I did HID's on the 850 with the aftermarket headlights I have. Some people have also put HID's in the foglights as well.
So it really all depends on which you really want to do.
Here is a place for the HID's http://www.sharphid.com/
Look on e-bay for the different headlights avalible.
Old Jan 21, 2009 | 01:40 PM
`98_S70_T5's Avatar
That's great! I will be looking at those sites and see if I can't find a decent upgrade. I also have a question about head lamp housing. Do I also need to buy a new housing for the bulb or just replace the bulb and that is it?
Thanks
Old Jan 21, 2009 | 01:50 PM
You can buy a HID kit with the bulb style that you have already Or what the new headlights will have it you buy new headlights then go HID.
Old Jan 21, 2009 | 09:53 PM
s70_t5_1999's Avatar
i discovered (since i live in the north country) that the light only goes on from 22 degrees to 36 degrees. it will shut off after 22 (assuming you KNOW its cold?)
Old Jan 22, 2009 | 12:02 AM
S70GLT's Avatar
ORIGINAL: s70_t5_1999
haha that's my thought exactly.
Old Feb 3, 2009 | 03:21 PM
BlazeS70's Avatar
just another little question...what makes HID's better than normal headlights?
Old Feb 9, 2009 | 02:36 PM
HID's dont use a filament, instead they are charged with a gas, and when electricity is run through the gas, the molecules get excited and produce a bright light. they are usually whiter then regular bulbs, but cost more and can be a pain to install. they need a ballast, a small box, to covert the electricity.
Woc2
Apr 2, 2015 12:42 PM
itisraffi
May 5, 2014 03:49 PM
drgonzophd
Aug 31, 2011 07:42 AM
everritte
Aug 11, 2011 11:09 AM
